I am using windows 10 in my system for a very long time. Couple of days back when I tried for the update of my windows 10 I got the windows-10 upgrade error 0xc1900201. I have tried several times to resolve the issue and tried by reinstalling windows 10. How to solve this?
What Is Windows 10 Upgrade Error 0xc1900201?
These issues usually occur due to corruption in windows update components. Run windows troubleshoot and fix the problems. Even then if the problem occurs, then to resolve it, try by changing the name of the software distribution folder. Sometimes altering the system reserved partition will also help in solving the error. If the upgrade crashes every time, then you need to change the way you are upgrading it. If nothing works, then try with the clean reinstallation method.
