I am using my system for two years from now. Nowadays, when I am trying to back up my computer, it is showing Windows-7 backup error code 0x81000019. The description says a shadow copy creation is not possible, check VSS and SPP application. It’s about space issues, but I have enough space in my system. What can I do now?
What Is Windows 7 Backup Error 0x81000019?
When the space in the system reserved partition cannot get enough space to complete the backup, you get this error. Even though you try to back up a small portion, you must have 40 MB free space to complete the backup successfully. Go to 100 Mb drive and compress the file to get enough space to create a shadow copy. Having too many windows language packs installed will also cause the error. Uninstall all the language packs and to backup now.
