What Is Windows 7 Update Error Code 8024afff?
I am using internet explorer for so long. Forthwith when I am attempting to update it is showing windows-7 update error 8024afff. All other updates are working well and can install except this. I have enough disk space and a good internet connection. How can I fix this problem and update it?
Answered By 0 points N/A #321094
Sometimes unknowingly you may have disabled some services. Debug them and enable their services and try to install them. Check the windows firewall is working well and no issues in it. Clear the internet explorer settings to the default and try. If it won’t help then try by deleting the temporary files and cache. You must also clear the unrelated codes from the system. If nothing works try for inbuilt Windows troubleshoot. You can set the windows update components manually to remove the error.
