What Is Windows Remote Desktop Connection Manager?
I am thinking to download Windows Remote Desktop Connection Manager on my computer. But what is it? What are its uses?
Remote Desktop Connection Manager helps a user to arrange and control the operations of a Computer that are available to the user through Remote App and Desktop Connections. It is same as Remote Assistance but a user gets the full level of control on the Remote Desktop including exclusive access to the files and programs.
To enable Windows Remote Desktop Connection Manager,
• Download the software via the Internet.
• Create a folder and save the Installer inside that.
• Select “Microsoft Application Virtualization Sequencer.” Click “Yes” on the User Account Control dialog box as it asks for making changes.
• “Microsoft Application Virtualization Sequencer” window appears.
• Select the option “Create a New Virtual Application Package.”
• Select the option “Create Package (default).” Click on the option “Next.” Wait to see “Select Installer.”
• Under “Select Installer for the Application,” click on the installed RDCM software of “RDCMan” by browsing. Click on “Next.”
• Under “Package Name” Enter “Remote Desktop Connection Manager” under “Virtual Application Package Name.”
• Browse for the created folder under “Primary Virtual Application Directory (Required). Click “Next.”
• It will say “Please Wait. The Installer will start momentarily.” (“Open file – Security warning” dialog box appears).
• Click on the option “Run.” License Agreement appears and click on the option “I agree.”
• Under “Select Installation Folder,” browse and select the “Remote Desktop Connection Manager” folder. Select the option “Everyone.”
• After clicking on “Next,” the installation will start.
• After the installation completes, go to “Start” Menu, go to “All Programs” and select “Remote Desktop Connection Manager.”
• In the next window, select “I am Finished Installing” and click on “Next.” Select “Customize” option and click next.
• Now under “Prepare for Streaming” select “Remote Desktop Connection Manager” and click on “Run selected” option.
• Click on “Next” until “Document the Package and select out options” shows.
• Click on the option “Create.”
• Press on “Close.” Now open the Remote Desktop Connection Manager folder and click on the App to check.
