What Is Windows Remote Management Ws-management? I Am Curious About It.
I read some where about windows remote management ws-management since then I have wanted to know about it. Does anyone know what it is and what function does it have?
Hello, Windows Remote Management is a part of the Hardware Management by Windows. It helps or well actually does manage the server’s hardware locally or remotely or both.
It has protocols like the WS-Management protocol (Easy to use protocol, designed to find and exchange information).
Baseboard management controllers(BMC).
The management has a lot more than what I have mentioned here. So if you want to know in depth functioning of this system, then you can go to Microsoft’s Management Specifications Index Page.
