I'm trying to install the Office 2010 Deployment Kit for App-V using a MAK activation key, a message appear:
Error message:
The product key you entered cannot be used on this machine.
This is most likely due to previous Office 2010 trials being installed. (System error: 1073418219
What is the issues of the Deployment Kit and Product Key?
Please check if you are using the correct MAK key. Provide a PIDKEY=parameter for the correct MAK key needed for the installation of Deployment kit. And also, Microsoft Office 2010 Deployment Kit for App-V works only with MAK so you need to check on the serial number if you are using a key for a Retail one. Here are the steps for installing Office 2010 Deployment Kit for App-V:
1. Download and Install MS Office 2010 Deployment Kit for App-V here. The setup will then extract it and ask for the location of the file.
2. Launch an elevated command prompt. Click StartAll ProgramsAccessoriesCommand Prompt and then select Run as Administrator.
3. Locate to the directory on the command prompt that has Offvirt.msi.
4. Run the following command: msiexec /i Offvirt.msi [feature flags][licensing flags]
Use the following flags that match your OS:
32-bit: ADDLOCAL=Click2runMapi,Click2runOWSSupp,Click2runWDS,OSpp,OSpp_Core
64-bit: ADDLOCAL=Click2runMapi,Click2runOWSSupp,Click2runWDS,OSpp,OSpp_Core,OSppWoW64
Ensure that you have entered the correct feature flags for the architecture or it may not function correctly.
You have to install Microsoft Office 2010 Deployment Kit Because it contains component required for license activation. Also Microsoft Office 2010 Deployment kit is required for sequencing or deploying Microsoft Office product with Microsoft Application Virtualization (App V).
Hi Karrie,
As well these solutions my recommendation also visit this Techyv post for more information about you problem.
Problem in installing office x
