I just had a downloaded eset nod32 antivirus free from the web.
I would want to hear anything from you guys about the pros and cons about it before I took my move into considering to change my antivirus entirely. A rating may be applicable but not necessary.
Thanks a lot.
What is it about the free eset nod32 antivirus download?
Hi Lee,
Hope you are fine. These are disadvantages:
1. Comprehensive protection: NOD32 was awarded by the Virus Bulletin.
2. for detection of all in the wild viruses in the test without any false alarms, that means it can protect your pc from most harmful viruses.
3. It can proactively detect viruses and remove them from your pc.
4. Can monitor incoming and outgoing traffic over the network with cyber monitoring function.
5. It's firewall software.
6. It provide both offline and online heuristic security.
The only disadvantage is that it slows down the speed of pc running xp. But it could not happen with the latest windows 7 (32 or 64 bit). Eset nod32 has also new version for 64bit OS.
Hope it will works for you.
Regards
Floyd
