Yesterday, I downloaded Kaspersky Antivirus 2013 ad I would like to know more about this software.
Is there anybody here who is using this antivirus? Can you tell me about Kaspersky side gadget?
Is it really useful?
Thanks lot experts.
What is Kaspersky side gadget?
Dear user,
Kaspersky is an antivirus software that is easy to download and easy to use. It protects your computer against viruses, spyware, rootkits and other threats too. It also detects new and emerging threats on your computer.
It is compatible with Windows 8. Kaspersky side gadget indicates whether your computer is protected or not and indicates it through color indicators.
Hope this will help you.
Thank you.
Hello Joshua,
Kaspersky Gadget is special feature of using who is running Kaspersky Internet Security 2013 under Microsoft Windows Vista or Microsoft Windows 7. Kaspersky Gadget is designed for fast access to the main features of the application including virus scan of objects, protection status indication and application operation reports.
Kaspersky Gadget uses to perform some main tasks, when you scan specified objects for viruses, to open the new windows and open the main application window.
Hi Joshua!
Kaspersky Antivirus 2013 is such a new breed of anti-virus for all of us. It has the unique integrated technology which is searching for unknown viruses that has the basic principles of the second-generation heuristic analysis. Because of this capability it has the ability to protect your gadget even from unknown viruses.
It also has the integrated Control Center in Kaspersky Antivirus personal which enables the user to create flexible schedules for the program components to be functional and automatically apply and download updates to the database of the antivirus through internet.
I hope this information will help you out.
Thanks!
