What kind of computer hardware is best so adobe products run smoothly?
I use Adobe Illustrator, Photo shop and Light room, but my computer can’t always handle the graphics. I will spend about an hour using a program and then it will take forever to load simple things such as a drop shadow when using Illustrator. What type of hardware should I get to help with this problem?
