What Kind Of Filehippo.com Malware Bytes Is Available?
Filehippo.com is the awesome place to download things from, and I need to know the kind of Filehippo.com malware bytes available in it. What are they?
There is a plethora of malware bytes or anti malware to download from Filehippo.com. There are various versions of Malware byte’s Anti-malware which detects and removes malware that is not possible even by the anti-virus standards. They can prevent malicious process happening in your system. They have features like high-speed scanning, full scanning, updates of databases, quarantining threats, context menu integration, etc. Download the latest version 2.2.1 which has 21.79 MB size available at the official webpage.
At the moment, there are several Malwarebytes applications you can download from FileHippo. Like you, I also download software from FileHippo because it is one of the safest websites to download commercial and freeware applications. Aside from that, FileHippo allows you to see the version history of every application.
If you need an older version of the program, you can go to the version history by clicking “View more” on the right. On the next page, you can select the version you want and download it. For Malwarebytes, you can download the following in FileHippo:
