Hello Guys!
Has anyone of you heard of the news of the latest development virus removal tool? Can anyone please share with us your knowledge? We need to be updated on the recent anti virus software which are now available. Has anyone tried this? Can you share your virus removal tool and explain its features and strength as well as its limitations if there is? How do you compare it with other anti-virus such as Kaspersky, Symantec, McAfee and more in terms of performance? Please give us guidance.
Thanks!
What is the Latest Development Virus removal Tool?
Hi Ana,
There are always new releases of antivirus software. Viruses are discovered almost daily and antivirus software companies strive to keep their software up to date. One good antivirus software is Norton. It has high user ratings due its regular updates and releases. Norton is a product that protects from both viruses and spyware.
The Pros of this software are: One, it installs very fast and does not take up too much memory on your computer which means your computer will not slow down. Secondly, it scans very fast and has automatic updates. However, it has one disadvantage that its advanced features are hard to learn.
The best antivirus depends on the needs of the user. But according to ratings, Norton, Kaspersky, Avira and Avast have a lot of successes.
Hi Ana,
The type of antivirus that is suitable for you is mostly dependent on your own personal preferences and requirements. Some people may require that their antivirus software offer protection when they are on the internet while others may simply expect simple virus protection from USB drives and so on.
Kaspersky antivirus has been the favorite of most users although some have reported it as being heavy on the system. The following infographic should assist you in your decision making.
