What is the latest feature of flash player pro 3.7?
I just heard about this flash player pro 3.7 version and was interested about the additional plug ins or features.
Tell me more about this version how it works and developed?
Thank you.
Ericson Eric.
Best Answer by Davidson Mudge
Answered By 5 points N/A #186197
It has the capability of the convergence of “SWF” and “EXE” flash movies.
This version provides you several bug fixes. You can play “Macromedia Flash movies.
By using a few mouse clicks you can make your own screensavers.
You can capture Flash movie images and set them as your “Wallpaper”.
There are several more good features in it.
The latest version “Flash Player Pro 5.4” is now available.
Answered By 0 points N/A #186198
Hi Ericson,
Adobe Flash Player 3.7 has sandboxing enhancements regarding the security, aside from fixing bugs and issues. It can also host SWF files to an external server which is downloadable to your IOs any time.
You can just copy and paste a URL and this program will grab and then play the video for you. It also supports Gamepads on Android gadgets. Back up for shared objects is now working, since this is needed to comply to Apple guidelines.
This also lets you capture screenshots of your favorite scenes or anything that will interest you so you can go back to it in the future. This also has SWF to EXE converter plus a screen saver maker.
