What is the latest Microsoft office system requirements?
Hi.  I'm planning to purchase Microsoft Office 2013.  Can someone tell me the latest Microsoft Office system requirements?  My desktop runs on an AMD Sempron processor, 2 GB RAM, 500 GB HDD, 1 GB Nvidia GeForce Graphics Card and Windows XP 64 bit.
Best Answer by Drake Vivian
Answered By 40 points N/A #139246
Your system configuration is more than enough to work with Microsoft office 2013, However, I have arranged a link , Which will be able to convey my message to you, Now I am sending the link, Simply click on the link given below and go through all the information. It will make understand Microsoft office requirement in better way.
https://technet.microsoft.com/en-in/library/ee624351.aspx
Thanks
Answered By 30 points N/A #139247
Hi there Gracekmakris,
Basic requirements for MS Office 20013 are the following:
1GHz or faster processor, 2GB of RAM, 3GB of space on your hard drive, DirectX10 graphic card with the 1024×576 or higher monitor resolution and one of the following operating systems: Windows Server 2008 R2 (64-bit), Windows 7 (either 32-bit or 64-bit), Windows Server 2012 (64-bit) or Windows 8 (either 32-bit or 64-bit).
So even though your computer configuration is fine and you are able to install the MS Office 2013, you should firstly upgrade your operating system to Windows 7 or higher.
Best regards,
Drake Vivian
