Green Scott
50 points
Posted on - 10/03/2012
I need the latest version of touch commander cab for my Windows Mobile project. I am using .NET Framework 2.0. The version that I have is the BETA. Though I do not receive any error message I've somewhere that it is better to use the latest version.
What is the latest version of touch commander cab?
Hi, Green Scott
As you know, from Google you can find a lot of forums but the chance of getting the right solution depends on where you post your problems. We have so many different forums to download the latest version of touch commander cab.
So classifying and posting them on relevant forums is the best way to get your answer step by step. I can suggest you some good forums, which are listed below:
1. http://www.fileguru.com/Touch-Commander/download
2. http://www.touch-commander.com/download-cab/
