What LCD/LED monitor brands are compatible on the windows8 touch-screen features?
Hi!,
I was wondering what are the possible monitor brands that are compatible on the windows 8 touch-screen features?.
I'm a windows 8 user and i think my monitor's brand does not  support the touch-screen features in the OS.
I hope to hear some answers,
Thanks in advance 🙂
Answered By 60 points N/A #177709
Touch screen monitors are new addition to the technological advancement. Though the concept is in the early stage, many quality brands have launched latest monitors with touch screen technology. Check out this touch screen monitors for your Windows 8 :
Samsung Series 7 SC 770
Available in 24" and 27", Resolution 1920X1080, Native Figure Contrast 5000:1 and MVA Panel.
Dell S2340T
23" multi-touch monitor. 10 point touch, Full HD resolution 1920X1080 max, DisplayPort, HDMI, Ethernet and USB 3.0.
Acer T232HL
23" Windows 8 certified Displays, 5 simultaneous touch points.
Viewsonic TD2220
22" (21.5" Viewable) TN panel, Resolution 1920X1080, 16:9 aspect ratio, Two point touch panels. Disadvantage : Missing an HDMI port, does not have 5 touch points for optimal Windows 8 touch experience.
Asus VG278H
27" monitor with Nvidia 3D Vision 2 Technology, 1920X1080 Resolution, 120 Hz panel, HDMI 1.4, Dual-link DVI and VGA inputs and two Audio outputs.
If you want more options then view this Top Ten Touchscreen Monitors Review. Hope this will help you find the appropriate touchscreen monitor for your Windows 8.
Best regards.
