What is the limit tmg upload file size?
What is the limit tmg upload file size? Sometimes we have to know the limitations of uploaded sizes depending on the file you want to upload on a specific software or application. Tell me more about tmg and all the features attached.
Markus Raine.
Best Answer by John Rular
Answered By 0 points N/A #187801
Infect there is no specific tmg limit for upload file size. But here I would like to say tmg file should not be so big. Big size file always take much time to upload. Small size file is better to upload and this always take time less time than big size file uploads.
Answered By 5 points N/A #187802
TMG files are one of the files required for backup purposes which include DOC, DBF, FPT, and MEM. The dataset is assigned a name containing one to seven characters. TMG is important since there are a lot incorrect file associations which causes the problems within your PC system.
There is no specific upload limit for the TMG file. Sometimes, the file upload limit is indicated by the website you are uploading to.
Click on this link for more info on TMG files: http://www.tmgtips.com/dbnames2.htm
