What is the link for best Linux English set?
Good day! I will just ask if someone knows the link for the best Linux English set.
I badly need this for my Gentoo Linux operating system.
Thank you so much!
Thank you so much!
Hello Tracy Killen
The solution software name is Gentoo Linux nvidia.It's an Gentoo Documentation resource file.Installing and buy this software on your computer can fix your solution.
Its a software collection of NVIDIA and you can install it from the software pack.
Hope this will help you.
With Thanks
Greaney Mary
Hello Tracy Killen,
The Best installation tutorial  is about Lucid Puppy 5.2.8, by Md. Hanbala.
To work properly with text data, your environment needs to be set up properly.
So it is easier to debug a problem which has encoding issues.
Please go to the following sites,
http://www.flickr.com/photos/mikogo/sets/72157629205072238/detail/
Mikogo English
https://www.linux.com/learn/tutorials/571815-the-2012-top-7-best-linux-distributions-for-you
https://wiki.gentoo.org/wiki/Handbook:Main_Page
Hope this works for you.
Thanks,
