What is a Mac software on an Internet to Direct record audio?
I am looking for a Mac software on an Internet that can direct record audio? Looking for a free software. thanks
Good day Belensienna
There is a free app called Soundflower which is good. you can download it here: https://code.google.com/archive/p/soundflower/downloads
There are several versions for this application.
After you installed it go to System Preference , in sound, output, soundflower.
There are a few applications you can use with soundflower to record with, like quicktime player. In quicktime player go to file, new recording.
A downward pointing triangle will appear in the recording window. Click and a menu will appear, choose Soundflower(2ch) then press record.
There are other apps like wire tap, and sound studio which is also an editing tool.
Download sound studio here: https://www.macupdate.com/app/mac/4811/sound-studio
Hope this help you.
Notifications
