What is the main problem to make the monitor resolution accurate?
Good day! Rezaur,
You posted a question about getting the resolution of your monitor fixed. The man reason behind your problem is that it might be possible; you have not installed the graphics card drivers properly.
The graphics card drivers installed completely would give you certain resolution options according to the size of your monitor.
I think you should check your drivers whether they are installed properly or not, and if they are not installed get them mounted into your operating system and then choose the best settings for yourself.
I hope this information will certainly help you.
Thank you
You should install your video card’s driver to have the right screen resolution for your monitor.
When you connect your monitor to your CPU through the video card’s port, the system will detect the highest and lowest screen resolution that your monitor can handle including the applicable refresh rates.
Setting a wrong refresh rate for your monitor might damage it that’s why you will only see in the interface only the allowable refresh rate values. There is no right or wrong screen resolution for the monitor.
It really depends on how you see your screen. Setting your monitor to a higher resolution will make the icons on your desktop smaller and likewise, setting it to a lower screen resolution for example 800 x 600 will, of course, make the icons a lot bigger.
It really depends on how you see it. If you want to make the icons smaller, set it to a higher screen resolution and vice versa.
