What is the major difference in Windows Professional and Home editions?
I currently have Windows 7 Home edition and wanted to know if we get better features in Windows 7 Professional.
Hi Abelina,Â
Your query is easy to solve and I will try to help you to the best of my ability. It will depend on where you use the Windows 7 version, since the various versions are made for the different platforms they are meant to be used such as the Win 7 professional edition for the office and Win 7 home edition for home use respectively.
Both of them have almost the same features but I would support Win 7 since it has office features and those that can be used as a home. The Win 7 professional edition is therefore the best version of windows that can be used all around since it has features that support the windows all round.
IÂ hope this solves your query.
