What is meant by “Google dance”
The term "Google Dance" is an out-dated slang used to describe period of time in which Google updated their indexes for their search engine. In this update the pages rank are being recalculated. In short, they rebuild their rankings and as a result of rebuilding, pages fluctuate in order during a several day period. This usually happens once per month or 36 times per year. In 2003, Google begun updating their indexes weekly. Listed below are some of the references I used regarding this topic and you can browse more from those websites if you have some technical things you wanted to know how Google Dance affects the SEO industry.
References:
https://webworkshop.net/google-dance
https://searchengineland.com/what-happened-to-the-monthly-google-dance-26452
http://www.forumdr.com/what-is-the-google-dance/105/
Thanks,
John
Google Dance is used to describe the index update of the Google Search Engine, which happens about once a month, but can vary. Basically, the "spiders" that they are often called, go through and get information from peoples websites, such as S.E.O. information and MetaTags.
Then, once a month, time varying, Google will collect this information, and change the Google Search, so that way all websites have a chance for getting on page one of Google search. Although, in retrospect, people often say that the bigger companies such as Walmart and best buy, when using a search term such as "Computers", will go down in SEO rankings. Which, is good for the smaller businesses. I hope this helps 🙂
Hi friend,
Google dance is a time period. There are many different definitions for Google dance. There is no final definition on it. But don’t worry. I search many sites and collect all data about Google dance so that I can avoid wrong definition about Google dance. Finally I am successful about it. Definition and meaning of "Google dance" is not as complicate as they say. The correct definition for Google dance is the time period when Google management team updates their site. It is a time period for 3 or 5 days and this time Google also rebuilding its rankings.
