I am trying a venture on flash animations and image editing. While learning stuffs and application about image editing applications and software, I stumbled upon the term called “media Image drivers” . What is media image drivers? Do I need to install this on my Windows Vista machine?
Its a type of file that flash is using. This images are used for creating flash animations. You need to install this in your machine so that you can create a lot more with your images. these are also drivers that help you on controlling the object is flash. These drivers are also available on the machine that views flash.
Hi Desiraealexa,
As i reviewed your issue, you are looking for your media image drivers for windows vista pc.
You can install media image drivers, Please follow the following steps:
1. First of all uninstall the imaging drivers: Control panel > Printers
2. Right click on the printer and select “Run as administration”, click delete > Continue > click yes
3. Return to the Printers menu and plug in the printer cable
4. Insert installation cd of printer and reinstall the drivers
Enjoy Imaging device.
I wish this solution may be helpful. Thanks!
Best,
Fenster Maxine
