mannddytiaa
30 points
Posted on - 11/20/2012
Hi
I have few files to extract from the dbxtract software. The version of the software is dbxtract version 5. I do not know anything about this software. I need a perfect tutorial for how to do this thing.
Help me
Thanks
What is the method of extract attachment from dbx software?
dbxtract version 5 is using for extract messages from your mail dbx files. It is basically for Outlook express. Outlook express is compacting mails when mail box is full. If your message box folder was damaged then you can use dbxtract for extract the existing massages.
Open the dbxtract software and then select the path of your Outlook express folder. Mostly it is in this path.
(C:Documents and Settings……..Local SettingsApplication DataIdentities {5E4715B6-F164-4336-9A55-76A9CC48433F}MicrosoftOutlook ExpressSent Items.dbx)
Then you can choose one or more dbx file to extract. ( dbx files are name as your outlook express folders. So if you want to extract your inbox folder then select inbox.dbx)
Then select output location. You can extract your messages into a desktop folder.
After the extracting process completed drag that extracted files folder into your outlook express mail folder.
I Hope this will help you.
Thank You,
John major.
