What is the method for missing sync smart uninstall Mac?
Hi guys. I hope all of you will be fine. I am using missing sync to connect with a PDA as well as cell phone to share photos, contacts and email from mobile to Mac computer. It sounds to be good but now I am unable how to uninstall it. I have tried by using deauthorize option but it is not working properly. Please tell me any method for missing sync smart uninstall mac easily. Any suggestion please.
Answered By 0 points N/A #131383
You can manually uninstall the software. First, go to the Sync software that you want to uninstall. Then, press the right button. You will see many options. Press “Move to Trash”. It will ask if you wish to delete it, then press the delete button.
Then, check the location: -/Library/Application Support/(Application)
Then you can mannualy delete it, and it will also delete the cache from here: -/Library/Caches/(Application).
After doing this, you should be able to fully uninstall it. Thanks..
