Trevor Jhon
40 points
Posted on - 10/05/2012
What is the most common transcription software? That will help the user to transcribe audio or any other format to be transcribed in the form of words and letters. I need to know the best software for this which can help to build a better online and even offline business work.
Thank you.
"Dragon speech recognition" is common and the best software for transcription purposes. It takes input from the user from microphone or in the form of wav file and writes in the form of text. It is very easy to use. And you can also find a video tutorial on their website. This software reduces your typing work just talk and it will type. The link for the software is as below:
https://www.nuance.com/dragon.html
