What is the most popular desktop recorder available?
I am trying to search for the best desktop recorder that can record all the activities on my desktop. Please include the step-by-step process and the correct configuration for it. I need the most popular desktop recorder available on the market today. Thanks.
Best Answer by Dennis Zeman
Answered By 0 points N/A #149606
Hi Samantha
I would suggest SCREENCAST-O-MATIC they offer two version of Desktop recorder first Version is for Free and other one would be for $15/year.
I have the free version been using it for almost 2 years now. I find it very useful although i could only record 15 minutes of my desktop since it's for free. Here are some key features of SCREENCAST-O-MATIC for FREE VERSION based on my experience.
  • It can record your desktop screen not only that it can also record coming from your webcam for 15 minutes
  • It's user-friendly as theirs only 3 Buttons to press (Record/Pause, Restart and Done)
  • You can Publish your video directly to YOUTUBE in HD
  • Publish your Video to MP4, AVI and FLV movie
  • No watermark when publishing
  • You could select part of your screen which you want to be recorded.
To download this Desktop Recorder you could click the link
On how to install it you could Click the link (Installation would just take 2-3 minutes)
Thanks!
Answered By 0 points N/A #149605
Cam studio is the most common.
With it you are able to record on screen even audio activity on your computer.
You can save them on a simple easy to use AVI format or convert it to the format you really want to use
The common features of the programme are as i have listed down below:-
1.  used to create demonstration videos for any software programs
2.  Used to record recovery problems with your computer
3.  Used to create video based information to show to the technical teams
4.  Has high quality screen captions
