What is the most popular windows tablet?
I am very much confuse with the windows tablet.
What's the most popular windows tablet?
Can somebody help me identify it?
I want to know what it is so that I could have one.
I only have android.
Samsung Galaxy Tab 2 10.1 is a modestly priced tablet. Samsung has some of the best-looking Android tablets on the market, and the Galaxy Tab 2 10.1-inch is no exception.
Samsung has once again turned to an all-plastic build,
Specs:
Android Ice Cream Sandwich 4.0
10.1-inch 1280 x 800 resolution, 149 pixels per inch
1.0GHz dual-core processor
1GB RAM
16GB of storage, expandable via microSD
Rear-facing 3 megapixel camera, Front-facing VGA camera
802.11 b/g/n Wi-Fi
Bluetooth 3.0
MicroSD card slot, IR blaster, 3.5mm audio input, proprietary pin input
10.1 x 6.9 x 0.38-inches
Nowadays, you can recognize a windows tablet if it has a built in physical keyboard or what they call hybrid tablet.
This hybrid tablets are portable like the other "normal" tablets, it has a physical keyboard where you can edit and type documents spreadsheets and make presentations like you would in a laptop or desktop computer. But, these windows tablet which usually runs on Windows 8 OS, requires a higher processor thus it is more pricey than its competition.
With regards to applications, Android out numbers it, and you cannot have the usual apps like the ones in Google play store or App Stores.
But, if you are going to use it mainly for business work, the Windows tablet can surpass its competitors.
Notifications
