What is most professional background?
I do a lot of Powerpoint presentations and my recent client told me that the background I selected was not professional enough.  I typically use something very plain, and in this instance, it was just blue.  I was curious as to what opinions were on the most professional background and should I always stick to the same one as my "signature"?  Thanks for your thoughts.
Answered By 0 points N/A #191051
There is nothing like a single background of the power point presentation which is the only professional background. You can use whatever color you want to use but make sure the color does not look deep. Background should be light colored. You have used blue color which is good but use light blue in the background. Also background is dependent on the content of your presentation. If your content is in deep blue then it’s not better to use a blue in background. Instead use plan white every time if you use deep colored content. Do not use red background any time for the professional power point presentation. If you are presenting the same client then do not use the same background every time. Modify the presentation background based on your presentation content, your client etc.
