What is the most reliable internet cleaner deep cleaner available?
Hi Ross,
One of the most reliable internet cleaner and deep cleaner as you described is « Ccleaner » this software can be very helpful for you, ‘’CCleaner is known as the most successful and effective for cleaning the internet browser and registry files also fixing files errors in addition of more options and tools available in Ccleaner for erasing traces,cookies,history of your net browser
And there is also ‘’Glary Utilities ‘’ which can be very useful basically does the same as Ccleaner but the only difference is that « Glary Utilities » contains more additional tools and options for pc speed up. I personally and highly recommend you to use Ccleaner for its simplicity and high performance tested and experienced by me personally.
If you want to free up as much space on your hard drive, using CCleaner will surely help you a lot. But for me, to free as much space as possible on my computer I use a combination of CCleaner and PC Tools Performance Toolkit. Download the free version of CCleaner and install it. Once installed, start CCleaner and clean your system.
After this, open your web browser and download PC Tools Performance Toolkit. Follow the instructions to download and unpack and then install it. Once installed, start PC Tools then go to “Privacy” tab and click “Clear Your Windows History.” On the next screen, make sure all items are checked then click “Clean All” and then wait until it is complete.
PC Tools Performance Toolkit clean all
Close PC Tools when it is finished then restart the computer.
1....
