What is most reliable Windos OS?
There are so many Windows OS nowadays and I don't know what is the best to use. What are the difference of latest OS and what is most reliable for daily use?
If you are looking to use a Windows based operating system, then the latest version of Windows systems yet, Windows 7 will be the ideal operating system to use. Although a customer preview version of the next generation Windows operating system has been released, it’s too early to say anything about windows 8.
Windows 7 supports all the latest hardware devices and most of the new hardware devices come with Windows 7 capability and support. If you are using a very old computer, it is recommended to use a older version of Windows operating system like Windows XP which supports your hardware devices.
A single OS has many different features that lead to its development into a more modernized version of OS. This version has solved some of the bugs of the previous O S and that some new features have been included in the process as such the new OS can be distinguished from the previous OS releases that the new one has many things new and fixed some old bugs. As such the new OS may be considered better than the previous. However some OS having declared new branded, may get some problems altogether. These problems are to be considered in recent time. Keep updating the system. Thanks.
Notifications
