pinkprom15
Posted on - 06/15/2012
I want to download a music sheet editor software on my iPhone but I don’t have any idea what kind of software should I download and I don’t know how to install it on my iPhone. Did anyone have any suggestions or idea? I do badly need the software. Thanks!
What music sheet editor software is the best for my iPhone?
Good day Pinkprom15!
I have read your post and you said that you need a music sheet editor application for your iPhone. There are so many kinds of music editor application is on the web and you could choose what is suits you. Well, if you were just a beginner or a pro in music editing, I would probably refer to you the Pocket Wave Pad by NCH software. Now, this application is well-matched with iPod Touch, iPhone and iPad, also requires IOS 3.1.2 or later.
Now in able to get this application, you need to go to App store and search the “Pocket Wave Pad”. You need to buy it and you can transfer it to your apple device and follow the instructions that will be given to you.
I hope this information helps,
Mark Amna
