What is music video on Open office and Excel?
I saw video clip on Excel sheet. I thought it was specially designed. But I couldn't realized it. What is it? How is it done?
It is possible to insert video on Excel 2010. User can be able to embed video files in a datasheet. But you cannot do it directly. To do this:
1. Open your PowerPoint 2010 and then create a blank slide.
2. Go to the Insert tab and then under the Video tab, select Video from file.
3. It will then launch the Insert video dialog box, select the video file that you want to insert and then click Insert.
4. Expand your selected video to fit the whole blank slide.
5. Save it and close.
6. Then open your Excel 2010 datasheet from which you want to embed the video file created in PowerPoint 2010. Go to Insert tab and then click Object.
7. It will open the Object dialog box, switch to create from file.
8. Browse to open the PowerPoint file that you just created and then click Insert.
9. When done inserting, click OK to continue.
10. The video is now successfully embedded in your Excel datasheet.
