What must I do to create a partition using disk administrator?
I have Windows XP.
The moment it’s running and I’m at the desktop with no programs opened, what must I do create a partition using disk administrator?
I have Windows XP.
If your are now at your Desktop. Please follow these steps to create a partition on your hard drive.
1. Press Start Button and Click "Control Panel"
2. After you Clicked "Control Panel", Press "Administrative Tools"
3. Your "Administrative Tools" will appear, Click "Computer Management"
4. Another page will appear, under "Computer Management" look for the "Disk Management" at the right side of the page.
5. Then you will be able to see your current Disk Management, and you can now create/format a partition on your hard drive.
Good Luck!
The following is how you go about using disk management to partition your hard disk in windows XP:
-Mathew Stone
