Hello experts,
What is this MySQL sqlite erm? I am wondering what is a MySQL sqlite erm? If you have some experiences dealing with this in mysql can you give me an over view on and other related topics that will best describe the subject? I really need the exact information.
Thank you.
What is this MySQL SQLite erm?
MySQL SQLite erm is a program software collection that executes a transactional SQL database engine, zero-configuration, self-reliant, and server less. It is the most far and wide organized SQL database in the world. The resource code for SQLite is in the open domain. Current expansion and continuation of SQLite is supported in component by SQLite Consortium affiliates, incorporating: Oracle, Adobe, Bloomberg, Mozilla and Bentley.
Best regards,
Heather marie
Hi there,
To understand the SQLite ERM you must first understand features of SQLite. SQLite is an in-process library that implements a self-contained, serverless, zero-configuration, transactional SQL database engine. SQLite may be embedded to SQL database engine but unlike most other SQL databases it does not have a separate server process. In short it is a complete SQL database with multiple tables, indices, triggers, and views, is contained in a single disk file. SQLite needs a different ERM(Entity Relationship Model) from the rest. This is due to its architecture. There are several tools for Sqlite Erlm. Check out this link http://www.datanamic.com/dezign/index.html
