Is it only developed on ribbon-style interface or added new function here? Is there added any zooming option? Is there any development on selection area? Can there include extra brush facility? Can I save images all graphic formats or Can I email them? Is there any difference in formal color patterns? Thank You
What new features included in windows 7 paint?
Hello Juan!
Here are the new and best features of Microsoft Windows 7 Paint.
1. Tool box – divided into two tabs, Home and View tabs. For Home tab you’ll find the resize and rotate tools, magnifier to zoom in and out. The View tab holds the rulers and gridlines.
2. Different types of brushes like for oil paints, crayon stroke, markers and watercolor.
3. Shapes can be easily drag on top of your images. You can also define it with your brush tool. Place in colors.
4. Color Palette – more tones and add more colors. You can edit and custom colors that you can use.
5. Ribbon menu – you can export your artwork to any file format using this option.
