What is this new Kaspersky Antivirus 13?
My friend told me about Kaspersky Antivirus 13.
He said that it is good to use and he said a lot of good things about this software.
That' why I'm very interested to know about this.
Is it a free software?
Is it worth downloading?
If so, then I will change my antivirus with this one.
Thank you experts
Best Answer by Fraserr thor
Answered By 5 points N/A #131092
Dear user,
Kaspersky is an antivirus software that is easy to download and easy to use. It protects your computer against viruses, spyware, rootkits and other threats too. It also detects new and emerging threats on your computer. It is compatible with windows 8. Kaspersky side gadget indicates whether your computer is protected or not and indicates it through color indicators. Unfortunately, it is not free to download but it is a good antivirus software.
It's customers are very satisfied with it.
Hope this will help you.
Thank you.
Answered By 0 points N/A #131093
It is really good. It will give you security from all kind of viruses, spam and other security threats. You can download 30 day trial from the website: https://usa.kaspersky.com/. If you want a licensed version, you have to buy it from them.
There are many advantages of Kaspersky Antivirus 2012:
1.  It protects your pc from all kinds of viruses.
2.  This is the latest version of Kaspersky Antivirus. The latest version always knows the latest news of viruses.
3.  It collects data from all users and can easily detect any kind of new and unknown viruses.
4.  It can easily detect phishing and malware websites.
5.  It can control all programs so that no software can make any harm.
6.  You have no need of downloading updates all by yourself. It downloads updates automatically so that can get the latest news of virus sector.
7.  It’s System Watcher is a unique technology. If any unknown malware tries to control your pc, it can be easily detected with this.
8.  It doesn’t make pc slower.
9.  While pc is running on battery, it automatically reduces power uses and save energy.
10.  Its interface is made easier to use.
11.  It is able to protect your pc while it boots up
So, you see that it has many advantages.
The trial is not more than 200 MB.
You can download easily.
