What is an oem computer editor and how it works?
I was wondering if somebody knows about oem computer editor? What is oem computer editor and what is its function?
Hi,Â
I am trying to answer to your question.Â
OEMs computer editor can add their own image and information to brand their computer easily. You can replace logo by funny pictures or add your own photo to the System Properties. You can include Manufacturer, Model, Support information and logo by it.Â
The full form of OEM is Original Equipment Manufacturer. It means nearly no CD/DVD, no packing case, no booklets and no overhead cost. It can be used as the synonym for lowest price. You can buy directly from Manufacturer; pay only for software and save 75-90%.
Hathy
An OEM (Original Equipment Manufacturer) Info Editor is a Windows application that lets the user add or edit their OEM information on their computer system. You can tweak the Windows System Properties with your own information or replace the logo with your own picture.
This application is easy to use. After starting the program, the OEM Info Editor will greet you with interface that will let you fill in some fields to edit your OEM information such as, your computer manufacturer and model, company, contact person, phone, mobile and fax number, email address, website. Address, etc.
It runs well with most Window based PC but requires an Administrator privileges when running on Windows 7. You can download it here.
