Hi everyone,
What is the official website for music theme for imovie? I would like to see or view all the possible themes. I don’t have any plan of downloading some but a little bit graphical information is much needed to create my own themes; this is just a basis or reference. Please show me more aside from imovies.
iMovie is a popular software for iOS in video editing. Â These days it allows you to turn ordinary videos to HD quality. Â It is designed for Multi-touch devices thus making it easy to just tap, swipe and drag to make your movie.
Currently it has twelve templates for you to use as your inspiration to create your own movie themes. Â It provides themes from fairy tales, to romantic themes and superhero adventures. Unfortunately, there are no other third-party API that creates downloaded template other than the one embedded on the iMovie software.
My suggestion would be to explore other video editing software like CyberLink PowerDirector 11 and Corel Video Studio. Â
CyberLink PowerDirector this software lets you ad music to your videos and still images. Â You can create a string of movies together with effects and unique transitions. Â This is a wonderful tool to create professional movies with a combination of audio clips. Â
Corel VideoStudio enables you to create 3D movies. Â You can also insert text and adjust the volume of your audio clips. Â The advantage of this tool is that it supports common file formats for importing and exporting photos.
