Juan M Flora 90 points N/APosted on - 05/01/2015
I am currently using Samsung Galaxy Tab 3 10.1 for the past two weeks. I have a great issue with the battery. I would like to know the correct duration for my tablet to charge completely? My tablet takes close to 10 hours to charge when I plug my charger in the wall and I wonder if that is right? What could be the possible cause such a long charge duration?
If you’re not charging properly, this problem will arise. Also, this might be the fault of your battery or your device’s OS.
First of all, make sure that your battery charges completely. Plug in your charger and charge your phone until it shows message that it’s fully charged. You can also see if it’s fully charged when the battery icon is full and tells 100% charge remaining.
Check your device for OS update. This is quite necessary as in some device, Samsung detected bugs that cause battery draining and fixed in newer software updates.
1. Connect your phone to internet.
2. Go to Apps >> Settings >> About device >> Software update >> Update.
3. Wait until the update downloads.
4. Install the update.
Some apps also cause this charge draining issue. If booting into safe mode fixes this charging issue, then it’s the problem of your installed apps.
1. Press and hold “Power” button until the “Device options” appear.
2. Long press “Power off” option until a warning message appears.
3. Tap “OK”.
Now, check if the problem still arises.
If still no solution, you should check your battery whether it’s in good shape. You might need to change your battery.
The Samsung Galaxy Tab 3 10.1 is a 4G tablet operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled on June 2013 and released on the third quarter of the same year measuring 243.1 x 176.1 x 8 millimeters and weighing 510 grams.
It uses micro-SIM card and has TFT capacitive touchscreen display with 16M colors at 1280 x 800 pixels screen resolution. It supports multi-touch featuring TouchWiz UX UI. It runs on Android 4.2.2 Jelly Bean powered by Intel Atom Z2560 chipset, 1.6 GHz Dual-Core processor, and PowerVR SGX544MP2 GPU. It supports microSD expandable up to 64 GB.
It runs on 1 GB RAM with internal storage available in the following capacities: 16 GB and 32 GB. The primary camera supports 3.15 megapixels featuring geo-tagging. It supports 720p video recording. The secondary camera supports 1.3 megapixels.
It has 3.5-millimeter jack featuring Dolby Surround audio enhancement; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 4.0 with A2DP support; GPS with A-GPS and GLONASS support; infrared; and MHL 1.2 microUSB 2.0 with USB Host support. It doesn’t have FM radio. It has built-in accelerometer and compass sensors. The pre-installed web browser supports HTML5. Java is not supported.
It runs on non-removable Li-Po 6800 mAh battery with talk time up to 9 hours via multimedia on 2G and 40 hours on 3G. It is available in garnet red, white, gold brown, and midnight black colors.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
