olivia.bha
70 points
Posted on - 05/02/2013
Hello experts! Have you heard about online fax tools? I work as a secretary to my boss and my everyday work routine is to receive and send communications thru fax.  I think this tool will help me make my job simpler. Does anyone know how can have this tool? What is the best online fax tool in your opinion?
What online fax tools can you refer?
Hi Olivia,
There are a lot of Online fax tool out there but this suggestion I’ll be giving is based on user review and what I think best suits you on your job making sure that document security is not at risk.
Kindly see the list below with features:
Popfax – This is a desktop program and lets you send and receive faxes from your desktop. You only need an internet connection to run this program.
Sfaxme – Top of the line of secured fax tools, this has an add on feature of digitally signing the documents and you can have an audit trail of incoming and outgoing fax.
Ring Central – Has the highest rank from user forums, it can send up to 700 fax compared to most fax tools that can have 500 fax as maximum.
More reviews and comparisons are found here.
Hi Olivia,
Indeed, there has been many products which have been released that provides similar services online. But the question is, which is the best product?
As for me I truly believe that all the best product asks for a reasonable price. It is not wise to go for a product that offers free services as you do not know if it is secured and usually it has limitations. So what I can recommend to you is a ClicktoFax online tool.
I have heard a lot of positive testimonials about this online fax tool which I believe it can make your job simpler. This ClicktoFax tool offers a 30-day Free Trial wherein you can test all the features.
Like I’ve said, free services have limitations. Every month you can only send 10 pages and received 10 pages all in. But what’s good about it is that, you will know if it does meet your demands and it is worth to go for Lite or Pro version with which you will need to pay for its remarkable service.
If you want to know more about this tool’s feature & pricing you can check it here.  As an added note, ClicktoFax has been awarded as the Best Online Fax in the year 2011 by vnfax.com and another award has been received as the Fax Product of the Year 2012.
You may also check the comparison details of ClicktoFax to its other competitor here so you can tell if this is the best one for you.
I hope this answers your concern.
Hi Olivia,
There are a lot of online fax services out there but I will recommend a few that you can check out.
1. Nextiva fax
This tool is best for sending a huge number of faxes as it offers 500 faxes a month and the fee after you exceed that number is very low. It can go as low as 6 dollars per month.
2. PamFax
This tool is integrated with Skype and it also supports different file formats not just PDF
3. MyFax
This is another tool that is best for international faxing. It offers 100 free faxes per month. It is well integrated with Ms office and Outlook.
