I need an information about the oracle export sqlite tools and its key features. What are its advantages and disadvantages? Also, please include a quick overview about it and its corresponding system requirements. I need a detailed information about the oracle export sqlite tools so I could also compare and contrast.Â
What is the oracle export SQLite tools all about.
Hi Samantha,
This is a 2 way conversion Sqlite to Oracle then vice versa. SQlite has more features like converting speed in bulk or quantified, specific mapping, conditional migrations. It can be used if you want to migrate between database on the same servers.
The benefits are it can save data in the Oracle dump to be exported remotely to Oracle server. It can support Oracle version 10.0 and higher. It does not require ODBC and Oracle client, then it also converts CBLOB, BLOB Sqlite conversion. It supports Sqlite 3.0 and higher, and it optimizes the size of Sqlite database.
You just need to set the needed privileges to make changes to the database on a remote server. You have Oracle XE or 10.x.x. Version. And your computer has Visual C++ 2008 x86 package (redistributable).
Should you get any error you can check the website here.
The Oracle Export SQLite Tool is an efficient and reliable recovery tool that can help you export Oracle to SQLite and vice versa, export SQLite db file to DB, MDB and MDF file formats, repair corrupt DB file database and export to healthy MDF, MDB and SQLite, etc.
Online you can find many resources on different software's and tools that can help you do these as well and export SQL database effortlessly too.
And to help you compare and contrast them.
