Good Day TechyV!
Can anyone please tell me what is the Outlook Express Bulk Import Vcard Process? I need to know if there is a way to do a bulk import of Vcards in Outlook. Please help me anyone, I need guidance. I would appreciate any tutorial lessons and demo videos.
Thanks for your help.
Alyss Aellaa
What is the Outlook Express Bulk Import Vcard Process?
Hi Alyss,
So Outlook does not support importing multiple .Vcf file at one time yet.
However, there are some workarounds that you may try yourself.
You may try using this macro that was shared by an MS Outlook MVP.
Check it here.
Alternatively, you may also use some third party programs that will do the trick for you. Listed below are a few.
Address Magic This tool not only converts address book formats but can also convert emails, calendar etc. to or from Outlook.
Vcard Converter Addin  This tool helps you import vcard to MS outlook, export outlook contacts to vcards and much more.
Keep us posted and hope this one helps you.Â
