Hi Guys,
I've been searching a function or a symbol of pause on the keyboard but couldn't find it. Is there any function for the pause in keyboard or a symbol? I tried some functions but it only stops instead of pause.
What is a pause symbol in keyboard?
Hi John M Elliott,
It’s a common thing you should know about that if you are using a computer keyboard for a long time.
Keyboard Pause key usually found on the top right corner of a computer keyboard.
It allows users to temporarily pause/halt the action of the program which is running.
Literally it is used in computer games to pause the game when user’s steps away from his/her system.
In this picture on top right you found the pause break key on computer keyboards.
This key will not found on apple keyboards.
Johnstoon Leen
