What is PfdMont file, any idea?
I am using Desktop pc and recently my pc is showing an error saying it is not able to find a file and the file name is PfdMont.
Does anybody here any idea about what this file is about and why is my pc showing this error and also please suggest some
solutions too.
Answered By 590495 points N/A #116979
I can not seem to find on the internet any legit error related to PfdMont file that went missing.
I also tried searching on my computer if I also have the PfdMont file on my machine thinking that it might be part of Windows operating system.
But I did not find anything with that name on my system.
I’m wondering if you had a recent download or you previously downloaded something on your computer let’s say an installer, a game, or something that required you to install it to your computer.
It is possible that this error is a virus. Try updating your antivirus and then run a full system scan on your machine.
It is also possible that the error is caused by the application you are using when the error appeared.
Maybe the application you are using has a missing file or corrupted file in the installation and it can’t load the file during initialization.
Try uninstalling the application you are using then install it back. This will fix any corrupted files in the installation and will also restore its settings back to default.
