I am thinking of using Mac Outlook with PGP. I have the Microsoft Outlook for Mac 2011 version installed on my notebook. Does anybody know which PGP software tool is most compatible for Mac Snow Leopard so I could encrypt and decrypt, as well as sign all my e-mails and files without any problems?
What PGP software tool is compatible for Mac Snow Leopard
PGP Desktop v10, Support for Snow Leopard 10.6 (x32 and x64)
Hello Lawrence
You can install Mac Outlook with PGP. From my reference PGP desktop tool is most compatible with Mac Snow Leopard. Using this tool you can encrypt and decrypt easily with all e-mails without any problem.
Use Google to find the tool, so many websites are offering it freely.
