Freddie Hart 0 points N/APosted on - 03/22/2012
Hello
I know most phones come with 3G, camera, Bluetooth, email, international device, music, and web browsing. The phones I looked at have all those features but it also either has windows mobile OS or Wi-Fi calling but no phone has both these features. Can u tell me if any phone does have both these features or if you don't know of any phone that does can you help me decide which is a better feature.
I would like to suggest you to buy Nokia Lumia 800. It's one of the most amazing mobile phones that I have ever seen and used. It has a seamless design with touchscreen display facility. Windows Phone 7.5 Mango operating system runs the mobile, has a strong WiFi connectivity adaptor. Internet explorer 9 is used here to browse the internet. It has an awesome camera of 8MegaPixel with 3x digital zoom which enables you to have the real taste of photography. The video quality is also very high. Route optimization maps and pedestrian navigation are also included here.
Overall, I would like to say you that you will be happy with this mobile.
I have been looking for a cool phone too! Thanks for the author for asking this question and thanks to the expert for recommending the Nokia Lumia 800. I have decided to buy it!
If you want a Windows phone that supports Wi-Fi Calling then you should try either Microsoft Lumia 950 or Microsoft Lumia 950 XL. Both versions support Wi-Fi Calling. The Wi-Fi Calling feature in Windows Phone started in Windows Phone 8.1 Update 2 as a native built-in feature.
Though Wi-Fi Calling is supported in Microsoft Lumia 950 and Microsoft Lumia 950 XL, you can only use it as long as you have a SIM from carriers that support Wi-Fi Calling. So, basically, Wi-Fi Calling is network-dependent. Now, before you can use Wi-Fi Calling, it has to be activated first.
To activate Wi-Fi Calling, connect your phone to your Wi-Fi network then on your phone, go to “Settings”, “Mobile + SIM”, “SIM settings” then slide the “WiFi Calling” toggle to the right to turn it on. Here are the specifications of Microsoft Lumia 950 XL Dual SIM.
The Microsoft Lumia 950 XL Dual SIM is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled to the public on October 2015 and released on December 2015 measuring 151.9 x 78.4 x 8.1 millimeters and weighing 165 grams.
It supports two nano-SIM cards and has AMOLED capacitive touchscreen display with 16M colors at 1440 x 2560 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass 4 with ClearBlack display. It runs on Microsoft Windows 10 powered by Qualcomm MSM8994 Snapdragon 810 chipset, Octa-Core processor (4 x 1.5 GHz Cortex-A53 and 4 x 2.0 GHz Cortex-A57), and Adreno 430 GPU.
It supports microSD expandable up to 256 GB. It runs on 3 GB RAM with 32 GB internal storage. The primary camera supports 20 megapixels with f/1.9, 26mm, Carl Zeiss optics, OIS, triple LED RGB flash, and autofocus featuring 1/2.4″ sensor size, 1.12 µm pixel size, PureView technology, panorama, HDR, geo-tagging, and face detection and supports 2160p video recording at 30 fps with stereo sound rec.
The secondary camera supports 5 megapixels with f/2.4 and 1080p video recording. It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band and hotspot support; Bluetooth 4.1 with A2DP support; GPS with A-GPS, GLONASS, and BDS support; NFC; FM radio; and USB 3.1 Type-C 1.0 reversible connector.
It has built-in iris scanner, proximity, compass, barometer, sensor core, accelerometer, and gyro sensors. The pre-installed web browser supports HTML5. Java is not supported. It runs on removable Li-Ion 3340 mAh battery with standby time up to 288 hours both on 2G and 3G and talk time up to 25 hours on 2G and 19 hours on 3G. It is available in black and white colors.
1....
