What is a PHP File?
I don't know what PHP files are.
I have some files from a colleague in PHP files.
How to open them?
Should I install some drivers or software's?
How to open them?
Hi Angela,
Your question here is about a PHP file, so allow me here to introduce to you about PHP file in a FAQ statements.
What is PHP file?
The answer is, it is a server-side scripting language.
Why did you get it?
If it is intentional sent to you, maybe your friend thinks it will be useful to you.
What do I need to understand PHP file?
You must have a knowledge in HTML/XHTML and JavaScript.
How to use PHP file?
You need a server to run it, and must install Apache (or IIS) in your server, install PHP, and MySQL Or look for a web hosting plan that caters to PHP and MySQL support.
I hope this will help you.
About PHP file agreed with david.
Note: Replace ABC to the file name which you want to open.
Hope this will help you to run PHP files
