What is Pioneer’s WiFi-enabled XDJ-AERO controller?
With what devices will the new DJ System be run-able?
Do we need any special software to run it?
And why is it more user-friendly?
Hello James,
The new DJ System had been made without the jumps and skips of vinyl, and it had come with a bad case of cable spaghetti, and there were spinners that bring their own kit to the party. But Pioneer identified all that and got rid of them with the new XDJ-AERO.
The New DJ System is WiFi-enabled and it allows you to load up the next Moombahcore banger directly from your Smartphone, tablet as well as a laptop or PC. This is done with the support of 4 connected devices at once. This implies that the audience can be able to be part of the track selection.
The XDJ-AERO has been made to work with Pioneer's own rekordbox application, but it allows the use of a MIDI controller for other popular software as well. When it comes to hardware, you will find a built-in 24-bit audio interface, a two-channel mixer as well as an array of cue-point triggers, FX as well as filters.
Carl
