jeffe major
Posted on - 10/03/2012
I recently bought a Samsung TV browser flash version. I noticed that it only plays flash and java supported files. Are there other plug-ins which are compatible with Samsung TV browser flash version?
What plug-ins are compatible with samsung tv browser flash version?
There are plug-ins recommended by Samsung, compatible with the flash player as an App Engine Plug-in. Its an application that's web-based software, but can run on Digital TV like Samsung when connected to the internet. Samsung SDK is a platform that allows you to create desired media applications thus enables you to integrate Flash functionality into your Smart TV. Both AIR for TV and Flash Player as an Application Engine plug-in are supported on the Samsung TV, but only the equality of the Flash Player as an App Engine Plug-in is supported. SDK App can be downloaded on the Samsung website developer forum.
Here is the link, http://developer.samsung.com/tv
Hello Jeffe Major,
My pleasure to help you.
First will see that what is a plugin. A plug-in is a bundle of Software components that adds specific abilities to a big Software application. If supported, plug-ins can customizing the functionality of an application. For an example, plug-ins are mostly used in web browsers to play videos, scan for viruses or to display new file types. Most known plug-in examples include Adobe Flash Player, QuickTime, and Java Applets.
Lot of sites there in internet to get plug-ins.
This is the official site for Samsung and the link will directly bring you to the correct place.
Enjoy it,
Thank you.
