Ava larry
10 points
Posted on - 11/05/2012
Hi techyv,
What is the possibility software to convert from cda to wma? I have cda audio files downloaded from the internet and needs to convert it to .wma file extension. Also give me ways on how to compress or lessen the file size such as kB to MB conversion.
Hoping for your help and kind consideration.
What is the possible software to convert from cda to wma?
Greetings Ava,
The first thing to know is that *.cda files are Audio “Data Index” files, which means that they do not contain audio samples, just CD index information. This also means that you can’t convert them if you don’t have the original Audio CD they came from.
If you do have the Audio CD, then follow these steps/Advices:
If you want a good sound quality with an appropriation file size, I personally advise you to use *.mp3 extension rather than WMA.
In order to convert your files, there are many software's on the internet:
FreeRIP Which is also available for free, it has a multiple file support.
Alt CDA to WMA Limited 15 Days trial version, has more conversion options.
Hope it helps.
Regards.
Travis Scott
Hi Ava,
You have asked about .cda to .wma converter software and I am here to help. The best Software to convert .cda to .wma extensions are Freemake Audio converter for me.
I'd choose the Software with my eyes closed. Freemake Audio Converter has the easiest interface which anyone can use. To convert any file (.cda, .amr, .mp3, .ogg etc) to another audio format just do the following:
1. First select the desired output of your audio file from the pane below.
2. Notice the +Add audio feature at the top left? Click it.
3. Add the audio files you want to convert.
4. Set the output folder from the File menu.
5. Wait a bit as it converts your files.
You are done. You can join several audio files into one with the join files' option at the top right.
Download The Converter From Here
